Check Engine Code p0420 2002 Durango
Old Apr 8, 2012 | 01:05 PM
dakotamagic's Avatar
dakotamagic
Question Check Engine Code p0420 2002 Durango
My check engine light came on in early February. The code was p0420. The mechanic I talked to took a look at my Durango and told me it was the catalytic converter.
I had the converter replaced yesterday and had the check light turned off. I was driving last night and the check engine light came on again. Same code. What's next?
Old Apr 8, 2012 | 08:31 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
the most likely reason for that code is the post cat oxygen sensor, NOT the cat. the
P0420 Catalytic Conv Eff
Old Apr 8, 2012 | 11:14 PM
IndyDurango's Avatar
IndyDurango
+1 SS. That is the O2 sensor code. Replace them all at once. Use OEM dealer product only. Enjoy another 100k+ miles problem free in that area.
And BTW, find a new mechanic.
IndyDurango
Old Apr 9, 2012 | 12:56 PM
mikeismadness's Avatar
mikeismadness
+1 most mechanics are just lookin for money, which isn't right. Always do a little research on a check engine code first, I had the code, turns out it was because my vehicle requires 91 octane fuel, and the dealership put in 87. It threw a lot of codes at me, ran the tank almost empty filled it up with 91 and the code went away, but has came back a few times when I ran cheaper gas. I run Mobil gas in my R/T now and haven't had a light in 2 or months!
Old Apr 9, 2012 | 05:32 PM
hydrashocker's Avatar
hydrashocker
Replace the after cat O2 sensor with a NTK or Desno sensor, I would not use any other name brand.
Old Apr 11, 2012 | 10:03 PM
dakotamagic
Cool, thanks guys! The check light has gone off on its own for now. I will replace the o2 sensors if it comes on again.
But in the meantime, "The Rango" is getting better gas mileage with the new cat! :-)
