i need help someone. im desperate!
You remove the exhaust manifold and hope there is some bolt shank left to hopefully get a pair of vise grips on it and turn it back and forth with a little penetration oil on it until you get it out. If that doesn't work you can get an "easy out" , drill a little hole in the center of the bolt and remove it with the easy out.
