Under Batt.
Old Apr 9, 2012 | 02:40 PM
Russ50's Avatar
Russ50
Default Under Batt.
Hey all,,, I trying to fig out what the heck is under my Batt. lol,, At the base of the plate where the batt. sets is a plug like an has 2 wires going to it from the bottm going up,, Has a spring like washer around it an can push it up an down a lil,,,, Well I was wondering if anybody know what the name of it is an what is it for,,, My Durango is a 98 model with the 5.2 eng. an 4X4
Old Apr 9, 2012 | 02:48 PM
RollerRed's Avatar
RollerRed
Can you get a pic up of it?
Make it a little easier to know what it is that way...
Old Apr 9, 2012 | 02:53 PM
Russ50's Avatar
Russ50
Ok RollerRed I will try right fast,, Thanks,, I did check the wire digram but couldn't find it,,,
Old Apr 9, 2012 | 03:02 PM
Russ50's Avatar
Russ50
I just took the pic but can't see how to put it in here,, Can anybody tell how,,, Thanks,,
Old Apr 9, 2012 | 03:34 PM
hydrashocker's Avatar
hydrashocker
It is called the Battery Temperature Sensor. It tells the PCM what temp your battery is so it will adjust the alternator output so it does not "cook" your battery.
Old Apr 9, 2012 | 03:37 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
+1 on what hydra said, its the battery temp sensor.
Old Apr 9, 2012 | 04:05 PM
alwaysclean19's Avatar
alwaysclean19
To answer your question on how to put photos up, you can either post them in a thumbnail on the site or you can use an image hosting site like Photobucket or Imageshack and then place it in your post. Second option provides better results for viewing on the site!
Old Apr 9, 2012 | 04:06 PM
RollerRed's Avatar
RollerRed
wow...we have that? fancy!
Old Apr 9, 2012 | 06:34 PM
Russ50's Avatar
Russ50
Oh ok,, Thanks guys,,,, Now I know what it is Plus learnin how to get the pic in here at one time,,, Cool,, Thanks again an goingh to work on the pic stuff,,,
