Overheating slightly at idle
Old Apr 27, 2012 | 01:32 PM
  #21
RollerRed's Avatar
RollerRed
Just throwing it out there. You can go to jiffy lube and they hook your D up to this pump. It runs new fluid in and pumps the old out. Cost like $80 but is worth a shot IMO.
Old Apr 27, 2012 | 03:17 PM
  #22
adukart's Avatar
adukart
That machine is very bad for trannies! It forces the fluid through putting pressures on things that weren't meant to take. Not to mention pushing any crud into the little valves and ports in the tranny. Purge it only that is the proper way, besides I have heard to many horror stories about Jiffy Lube. Wow just read you guys are talking about coolant flushes, . Any ways remember coolant flushes can expose weak spots in your radiator and heater core also.
Old Apr 27, 2012 | 03:36 PM
  #23
RollerRed's Avatar
RollerRed
Nice adukart! haha
But yea I did it a month ago and I had found a couple of things that needed changing. But better then, then when I am flying down the freeway at 70 in Aug when it is 100 out side!
Old Apr 27, 2012 | 03:56 PM
  #24
otgarzā's Avatar
otgarzā
Oh jiffy lube. I had a buddy that got a coolant flush there and they put the wrong coolant in and caused his upper and lower hose to slightly leak. Luckily we flushed it out ourselves later, reattached the upper hose, and replaced the lower hose and clamps. It may be good for some vehicles, but it can cause problems in others.
Old Apr 27, 2012 | 11:40 PM
  #25
hydrashocker's Avatar
hydrashocker
I got a better idea!
Just take the truck to Compton and give a thug $100 bucks to blow it up. It will be cheaper and you will still get the insurance money for it!
Seriously!
I wouldn't pull my truck into a Jiffy Lube if you PAID me for it! (Well I guess it would intel on how much you gave me at the time, but that's beyond the point!)
Those losers couldn't fix a wiper blade! Instead they would tell you that the OEM equipment is wrong and set you up with something out of their computers.....Bunch of dumb asses.......IMHO!
Old Apr 28, 2012 | 09:59 AM
  #26
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
i agree jiffy lube causes many more problems than they solve, i would stay away
Old Apr 28, 2012 | 09:41 PM
  #27
otgarzā's Avatar
otgarzā
Boycott jiffy lube! Lol. Thats what ive always said. Theyll "change your oil" but forget to put a new oil filter on, leaving you with the old one
