03 Durango No Power Center Console or Heated Seats
Hello,
I am having a problem with my 03 Durango. I have no power to the center console outlet, as well as the heated seats. I get no LEDs flashing when the switches for the seats are pressed. I have looked in my fuse box and all seem to be good.
Any suggestions that anyone may have would be greatly appreciated.
Thank you for your time and help
1) you need to read the rules before you post https://dodgeforum.com/forum/dodge-d...s-section.html (this thread is in the general section which you should not be posting in, your post has been moved to the correct section (1st generation)
2)check the fuses in the PDC (black box under the hood) the center console power outlet is powered by a fuse in there, not in the door jam (so is the power outlet in the back by the hatch, same fuse actually).
also a visual inspection of the fuses is not good enough, need to do a continuity test on them
