Old Aug 10, 2015, 05:18 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Electrical Guides
Print Wikipost
Truck wont start. click's once please help
Old Apr 27, 2012 | 01:18 PM
itsnick's Avatar
itsnick
I removed the positive cables and cleaned all the **** out then installed a new connector and the truck started right up.
Thanks guys I wish I would have posted before diagnosing the problem myself, the starter was probably fine :/
Old Apr 27, 2012 | 03:27 PM
otgarzà's Avatar
otgarzà
Glad you got it fixed...loose connections and corrosion are the enemy, but always remember to check the terminals as well
Old Apr 27, 2012 | 11:31 PM
hydrashocker's Avatar
hydrashocker
Your welcome,
have a great time on the forum and keep a keen eye out for those people that can accurately diagnose, explain why you are getting the issue, and give the the fix for it.
Usually their right!.......
Old Sep 22, 2012 | 09:55 AM
mgbella's Avatar
mgbella
I have a similar situation except no clicking and I've cleaned corrosion as well. I have a Dodge Durango 1999 won't start. Everything turns on when key is turned in ignition but doesn't click or anything, I changed the starter fuse and it started right up for a day...next morning same issue. What else can I check
Can anyone help or anyone out there experienced the same thing...Starter is at most year old, fuel pump replaced last winter, battery is only a couple months old....at a loss
