Electrical? No crank and repetitive clicking stumped!
Old Apr 27, 2012 | 05:33 PM
mechanicaljosh's Avatar
mechanicaljosh
Default Electrical? No crank and repetitive clicking stumped!
First off I have a 99 Durango 5.2 4wd 136,xxx mile. Never had a problem before.
I'm no good at figuring out electrical problems. so today i shut the engine off after pulling up at the local scrap yard. And was going to move out of the way for the next customer. I went to start it and...."click" fallowed by more "clicking" even after the key was removed. (passenger side kick panel).
I checked the connections, cleaned and replaced where needed. fuses all good. Relays...the fuel pump relay and auto shut down clicked a few time then stoped. After towing it back home I was going to lock the door(w/fob) and would NOT work. I'm in need of help per this is my family only transportaion. Please HELP!!!!!!
Old Apr 27, 2012 | 06:33 PM
topdogcustoms's Avatar
topdogcustoms
How old is the Battery
Old Apr 27, 2012 | 06:47 PM
mechanicaljosh
im not sure. it was on there when i bought it. IT IS fully charged though
Old Apr 27, 2012 | 11:19 PM
IndyDurango's Avatar
IndyDurango
+1 topdog.
Click, click, click is standard for no power. Check the batt and ALL connections from batt, to PCM back to starter.
IndyDurango
Old Apr 27, 2012 | 11:26 PM
mechanicaljosh
I have checked the connection and battery.
Any have a clue on the clicking sounds.
Old Apr 28, 2012 | 12:19 AM
topdogcustoms
have you had a load test done on the battery a weak battery will cause horrible problems with a durango
Old Apr 28, 2012 | 12:47 AM
hydrashocker's Avatar
hydrashocker
Again battery or terminals are corroded. Clean the crap out of the terminals and have the battery load tested.
