Trans pan gasket question
Old Apr 30, 2012 | 08:45 PM
hoyt66's Avatar
hoyt66
Originally Posted by Duranged408
I'll 1 up ya, whenever i do a transmission service myself i buy a new pan with the gasket, great to have a fresh new edge/gasket to keep everything clean
Where do you get your pan at? How often do you do that?
Old Apr 30, 2012 | 09:02 PM
Duranged408's Avatar
Duranged408
Unless you are having problems you shouldnt really need to access your filter/pan other than the recomended "sched" of maintenance. Im very very abusive to my d with towing/heat/etc, the first replace was from a dealer, the second time i replaced it with a hitech, third time stock again (sh*t breaks).
Old May 5, 2012 | 02:56 PM
Mean Green's Avatar
Mean Green
Any rubber gaskets, o-rings, or seals I replace I just use the oil I have at hand which will be the fluids I'm replacing.
Old May 6, 2012 | 05:00 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
i do the same as mean green, w/e fluid im working with gets used to lubricate gasket
Old May 6, 2012 | 11:22 PM
hydrashocker's Avatar
hydrashocker
I'm not stating anything about using the lubricant in which the gasket is being used to use to seal it, but instead I question the ligamentcy of which....Simply stating I don't know if the lubricant in which a person is designating the gasket to seal doesn't in fact decompose the gasket in which they are replacing.
So with that I always use Mobil One Fully Synthetic grease, or multi-grease complex, when seating rubber gaskets regardless of the intent designated. But that is my choice, and if something comes up that I don't know the fluid used I always read up on the MSDS sheets to ensure my analysts will work with the fluid I'm using...Blah Blah Blah.
Old May 6, 2012 | 11:37 PM
Russ50's Avatar
Russ50
I change my trans fluid an got the filter an rubber gaset an cleaned the pan up an trans where the pan goes and not have ant probs at all,, I don't use anything with a rubber gaset at all,,
