ball joints
Old Apr 30, 2012 | 04:40 AM
srch4me's Avatar
srch4me
Default ball joints
So my salvage yard parts need ball joints. Are the upper and lower joints the same? What's a good greasable joint. Don't have the funds for moog currently.
Old Apr 30, 2012 | 06:43 AM
acfd813nick's Avatar
acfd813nick
No i dont think they are the same not sure what year yours is but on my 02 the uppers had 3 rivets and the lowers had 4 and they where a PITA to get apart
Old Apr 30, 2012 | 08:18 AM
Old_School's Avatar
Old_School
Adam,
The uppers (if replaced by the recall) should have 3 bolts that hold it on and are generally a piece of cake to replace...
The lowers are pressed on and you will either need to pay a machine shop to press them for you or buy the kit from harbor freight....
http://www.harborfreight.com/four-wh...-kit-4065.html
Like everything else on or trucks a good penetrating oil is your best friend.. the lowers can be a bear to break depending on how long they been in there. If you have access to a air impact driver, that can quickly become your friend too...
Here is a kit that gives you everything you need for the front end...
http://www.ebay.com/itm/SUSPENSION-D...66344718873268
HTH
Old Apr 30, 2012 | 05:02 PM
otgarzà's Avatar
otgarzà
Same on mine...replaced the uppers last year
Old Apr 30, 2012 | 05:30 PM
srch4me's Avatar
srch4me
So there aren't bolt on lower ball joints?
Old Apr 30, 2012 | 05:43 PM
acfd813nick
No on my 02 i had 4 rivets after i replaced them the new ones came with bolts just put them on where the rivets was
Old Apr 30, 2012 | 06:47 PM
hoyt66's Avatar
hoyt66
Forgive my ignorance...do you have to chisel the rivets off?
Old Apr 30, 2012 | 06:49 PM
Old_School's Avatar
Old_School
Nope yours are pressed in
Old Apr 30, 2012 | 06:50 PM
acfd813nick
I took a grinder to the head of the rivets then drilled them as deep as i could go and then hammered and punch the rest of it out the uppers was real easy as far as gettin the rivets out but the lowers was a major pain
Old Apr 30, 2012 | 06:51 PM
Old_School's Avatar
Old_School
that or drill them out
