98 D power windows
Hey,, Would anybody have a diagram for the drivers side power window,,, I need to see how the cables are pos to be,, Mine has been off since I have owend it an just now getting to it,, The metal slot plate at the bottom of the door glass is off of the glass, I think I will have to get a new glass with that plate glued to the glass,, But I trying to fig out how the cables are pos to be hooked up at the long track bar that the glass slides up an down on,, Hope somebody can help with this,, I have never took one on a D off before so I don't know how the cables are pos to be,, Cables are still hooked up to the motor an also hooked up on the plate that bolts the glass to,,
I will take a pic of it layed out tomorrow an try to add it on here,,, I been haven bad probs trying to get pic on here thats why I didn't get the pic,, An yea you said it right,,lol,, Then you have the 2 cables going from the motor to the flat plate that slides up an down on the track then the bottom of the glass has a plate that bolts to the plate on the track,,, I took mine all the way out cause its all messed up an I found out that the 2 cables are jam inside of the motor cover, an the cables are no good at all, So I going to junk yard in morning an get the glass an track an cables an motor cause its alot easyer to get it all together,,, An Thanks
Thanks srch4me,,, I have the manual but can't seem to find that fuse box under the dash in it,,
