Over Drive (O/D)
Old May 4, 2012 | 09:16 PM
Old_School's Avatar
Old_School
Originally Posted by FirePro911
When I pull the boat, I turn it off.
D has to turn the 35's and pull a heavy boat and it is tough on it. The 356 gears help a lot.
That D looks like a midget next to that BIG boat...lol
Old May 4, 2012 | 10:14 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
when youa re towing heavy loads leave OD off even on the highway, just slow down a little and take it easy its better fo ryou and the truck
Originally Posted by samnbensdad
Why???
i turn it off for a few reasons, (ill explain how o/d off works after)
1) better engagement/shifts (firmer and less slipping into gear)
2) holds gears longer
3) as stated above you get a little engine braking effect out of it
4) better efficiency around town
the way the O/D off works in these trucks is very similar to tow/haul (some actually say tow/haul instead of O/D off). It locks out the OD gear, it firms up the shifts causing less slip of the clutches, it increases fuel efficiency by having a tendancy towards locking up the torque converter (much more than w/ O/D on), all of this does alot of good to help with the life of the transmission and the fatness of your wallet over time.
Old May 4, 2012 | 10:24 PM
samnbensdad's Avatar
samnbensdad
I always assumed it was worse for mpgs around town since the RPMs are increased.
Old May 4, 2012 | 11:14 PM
adukart's Avatar
adukart
Less of a load on the engine though. Plus the torque converter is locked up more often increasing transmission efficiency.
Old May 6, 2012 | 01:01 AM
hydrashocker's Avatar
hydrashocker
Read your owners manual, it explains what you need to do.
Old May 6, 2012 | 05:15 PM
shrpshtr325
THE ULTI-MOD
in practice your transmisison will shift into O/D below 45, in theorey this shouldnt happen, locking it out stops it from happening, and gives you better response when you step on the go pedal, if has dropped into O/D at 35, it will need to shift twice to get to passing gear if you need to really get moving, w/ O/D off it will need to make one shift. Also as stated witht he torque converter locked up there is a large decrease in losses through the transmission.
