Who has the highest miles on their 1st generation Durango?
Old Jan 7, 2014 | 08:03 PM
  #81
PublicHair's Avatar
PublicHair
AC compressor is ****ty. Aftermarket sucks.
Old Jan 7, 2014 | 09:12 PM
  #82
jjjefferson's Avatar
jjjefferson
Default Still Lumbering Along....
168K on my 2000 Durango 4X4.
Lots of maintenance ... still some left to do. Replacing the OEM Exhaust next...usual stuf
Ball Joints, Tie Rods, Wheel Bearings, Radiator, A/c Compressor, TPS/IAC/PWR Steering Sensors Water pump, T-stat, hoses etc.
Did the overhead console upgrade....wish I hadn't...LOL. NOw I see what the gas mileage is ever time I look up. LOL.
Old Jan 7, 2014 | 09:29 PM
  #83
jjjefferson
I've had good luck with my replacement from discountacparts.com
Just make sure you get the higher compression model if you have the rear A/C unit.
Old Jan 7, 2014 | 09:59 PM
  #84
PublicHair's Avatar
PublicHair
I searched out for a denso replacement unit. OEM stuff. I don't want to drop $500 every time it goes out. I replaced it twice in two years. This time around it sounds like a super charger. So I disconnected it and running a smaller belt. Don't need AC anyway -
Old Jan 7, 2014 | 10:01 PM
  #85
that_guy's Avatar
that_guy
I'm glad my original compressor is still working fine from the sound of it.
Old Jan 7, 2014 | 10:03 PM
  #86
PublicHair's Avatar
PublicHair
Yeah. Keep it running. From what I've seen on the net is a high failure rate.
Old Jan 7, 2014 | 10:05 PM
  #87
that_guy's Avatar
that_guy
Why not just get the original one rebuilt though? It's usually cheaper or the same as getting a replacement, but you get to keep the OEM quality part.
Old Jan 7, 2014 | 10:11 PM
  #88
PublicHair's Avatar
PublicHair
Mine is an OEM rebuilt.
For some reason **** just not as good. A bit upsetting because the cooling isn't as good as it was. A real shame.
Old Jan 7, 2014 | 10:18 PM
  #89
that_guy's Avatar
that_guy
Yeah, that would suck
Old Jan 8, 2014 | 09:13 AM
  #90
wralyn's Avatar
wralyn
I'm in South Texas, so a good AC is a must. I replaced the OEM with a Napa. It's lasted about two years. It still works, but it rattles quite a bit when it kicks on. I'm sure the bearings will be going out any day now. Cooling is horrible compared to the OEM. I took it back and had the shop recheck it because I thought they hadn't charged it properly. I didn't realize compressors could be rebuilt or that aftermarket was subpar. The original unit is long gone.
