battery draw fuse #22 2000 4.7 durango
Old May 10, 2012 | 01:26 AM
Tim Boyd's Avatar
Tim Boyd
Default battery draw fuse #22 2000 4.7 durango
hay guys got a battery draw on fuse 22. its marked trans on the cover 20amp. makeing me nuts. i pulled each wire from the trans one buy one and still a draw on the testlight. i dont know wat else is on this circuit . has anyone had this problem or know the answer to my draw. it pulses (the draw).
thanks for any input im open to any sudjestions .
Old May 10, 2012 | 02:09 AM
krupaeric's Avatar
krupaeric
i had a power draw on my tranny to but not sure if its the same as yours. mine was because the neutral safety switch wires were worn together. the insulation was dry rotted and caused the wires to cross. causing my reverse lights to stay on while i was in drive and it was also causing my tranny to slip. i got a 98 5.2ltr with a 44rfe transmission.
Old May 10, 2012 | 07:43 PM
Tim Boyd's Avatar
Tim Boyd
Im sorry fuse 23.
