32/11.50/15
Old May 10, 2012 | 03:42 PM
TurboStixx's Avatar
TurboStixx
Default 32/11.50/15
I pretty sure I know the answer, but with a TS lift, will these fit??
Old May 10, 2012 | 04:09 PM
Dirtrango's Avatar
Dirtrango
I think the answer is TS lift and a 3" body lift. that's what I'm planning on soon.
Old May 10, 2012 | 04:19 PM
TurboStixx's Avatar
TurboStixx
I have the TS lift already, can't afford nor am I doing the body lift (wife already has trouble getting in the truck seeing as she is only 4'10") Was just wondering because a buddy has a set of 4 for sale for $300 with half tread...and I need new tires for inspection lol...but since not I guess I will get these, or another one I found if I can find someone with them in stock
http://simpletire.com/falken-31-10.5..._campaign=feed
oh oh I like this one more and same price! http://simpletire.com/nankang-31-10....22285003-tires
Old May 10, 2012 | 06:17 PM
RollerRed's Avatar
RollerRed
They will "fit" I guess your running stock rims as well?
They will rub some, then again they may not. Every D seems to be different. My friends D is running 32's but he has different rims with a BS of 4.5" or something,(ours are 5.5").
IF your carefull you could pull it off...
Old May 10, 2012 | 09:57 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
32 inch tall tires will fit w/ a t/s lift, 33 inch tires will not
Old May 10, 2012 | 10:08 PM
jmess's Avatar
jmess
i dont see you having any issues with them. i ran 33x10.5 on the stock 15 inch rim and had no rubbing issues on he body
Old May 11, 2012 | 09:48 AM
TurboStixx's Avatar
TurboStixx
ok, so the 32s could fit, and from what I look at on the truck they could work, i guess my next question is will the fact that it is 11.50 and not 10.50 be a problem?
@rollerred-What do you mean if I am careful? Like if I don't take any sharp turns?
Old May 11, 2012 | 12:21 PM
jmess's Avatar
jmess
You might have some rub on the frame in full lock
Old May 11, 2012 | 03:26 PM
RollerRed's Avatar
RollerRed
yea +1 on jmess
turning while going over a bump, or just full lock mabey...
Its one of those you will have to thorw it on and see.
