Cold trans
Old May 12, 2012 | 08:43 AM
hoyt66's Avatar
hoyt66
Default Cold trans
Another question guys/gals. I just bought a used 2003 D w an alleged 76000 miles on it. When the D sits for a couple days and I start to take off
it's like the trans is in "1st"gear for a minute until the trans warms up. It kinda of "tanks" forward like a truck in 4 low. Is that characteristic of the
4.7? Thanks
Old May 12, 2012 | 03:47 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
normally they are a little sluggish after an overnight sit because the clutch fan is engaged, once it disengages you are usually fine from then on.
if this is not what you mean then idk what you are trying to describe, my 4.7 acts normal on a cold start with the exception of what i just described.
Old May 12, 2012 | 04:48 PM
jmess's Avatar
jmess
thats what i assumed he was talking about. my 5.9 does the same after sitting for the night
Old May 13, 2012 | 08:26 AM
hoyt66's Avatar
hoyt66
Yeah, that's probably what I'm experiencing. Thanks
Old May 13, 2012 | 09:14 AM
shrpshtr325
THE ULTI-MOD
the clutch fan will also make quite a bit of noise until it disengages, this is normal for a short while after a long spell off.
Old May 16, 2012 | 04:03 PM
Groggy's Avatar
Groggy
Default "trans"
I really think that he is describing a sluggish torque converter after the fluid pools back into the pan and the pump needs to get it powered back up.
Mine does the same thing, but only takes 10-15 seconds to "get right".
Old May 16, 2012 | 08:50 PM
hoyt66's Avatar
hoyt66
Hey nice set up!! Yeah, it probably only takes about 15 seconds or so. I said a minute originally but it probably shorter.
