2002 Dodge Durango
need more information, which engine is in it? 4x4 or 2wd? what trans is in it?
no bus means that the PCM is not communicating with the gauge cluster, it could be a few things including a bad PCM or a bad cluster, or as simple as a loose connection in the wiring
P0920 Gear Shift Forward Actuator Circ/Open
P0921 Gear Shift Forward Actuator Circ Range/Perf
P0960 Press Ctrl Solenoid A Ctrl Circ/Open
P0999 Shift Solenoid F Ctrl Circ Hi
