Something's wrong with the bass
Old May 19, 2012 | 11:59 PM
alligatorsgorawr's Avatar
alligatorsgorawr
Default Something's wrong with the bass
I recently bought a 2000 Durango from a friend, it's only problem is, the bass doesn't work very well, when i leave it about mid-way, the music is fine, but as soon as I turn it up a little it sounds crappy. Any idea how to fix this? I really don't know much about fixing cars, so any help is appreciated.
Old May 20, 2012 | 01:45 AM
IndyDurango's Avatar
IndyDurango
Are the speakers all blown? Probably. Easy to pull the door panels to see.
Stocker speakers don't last too long. Just spent all day replacing mine on my 2nd Durango.
IndyDurango
Old May 20, 2012 | 02:15 AM
alligatorsgorawr
How do you tell if they are blown? wouldn't they not work at all then?
Old May 20, 2012 | 02:40 AM
IndyDurango
Pull the door panels and look. VERY common to find them totally deteriorated all around the cone.
They will still work, poorly... hence your original post.
Old May 21, 2012 | 04:00 PM
Old_School's Avatar
Old_School
IndyDurango
Speaker recomendations?
what ones are a direct fit to the factory ones?
Old May 21, 2012 | 07:11 PM
autoshh's Avatar
autoshh
For a little more info: If your D has the factory-installed BOSE system, the speakers are wired strangely back to the head unit, so if you do have the BOSE system and the speakers go, you'll need a new head unit and wiring, which can be tricky.
This aside, if it is your speakers, you should see a broken rubber seal along the outside. This can cause a loss in bass but not upper tones.
Old May 21, 2012 | 11:09 PM
Kensai's Avatar
Kensai
I think our 1st generation durangos are Infinity systems. NOT BOSE.
Old May 21, 2012 | 11:38 PM
IndyDurango
+1 Kensai Infinity
Old_S, 100s of threads on the very same thing here there and everywhere.
Old May 22, 2012 | 01:51 AM
TiesTorN's Avatar
TiesTorN
Mine were also blown (all of them). I just went to an Auto Audio shop that I find on the road and replaced all of them with Alpine's... Now it's excellent.
Old May 22, 2012 | 11:27 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
+2 on the speakers being inifinity not bose
