Plenum, Tuneup, and CAT.
Old Jun 13, 2012 | 08:22 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
OEM cat is a high flow CAT already, no reason to spend money on one marketed as 'high flow', just replace w/ an OEM unit and move on with it.
Old Jun 14, 2012 | 08:31 PM
tank99Dango's Avatar
tank99Dango
thing about it is..the magnaflow high flow cat is cheaper than the stock "high flow" cat...I would still buy magnaflow over factory any day..
I know this is universal fit, but with any welder, it would work fine..costing less than throwing money at rock auto, summit, or any high dollar supplier
http://www.ebay.com/itm/MagnaFlow-99...ht_5189wt_1135
Isn't the usual smell of a converter going bad is the smell of rotten eggs? I occasionally get my check engine light on, Bank 1 sensor 2 o2 sensor..then it goes back off...only shows code if it has been running for more than 20 minutes at idle...
Old Jun 14, 2012 | 10:07 PM
shrpshtr325
THE ULTI-MOD
a CAT that is no longer functioning smells like rotten eggs, however we are talkinga bout a clogged CAT situation here, it needs to be replaced.
Old Jun 16, 2012 | 01:13 AM
hydrashocker's Avatar
hydrashocker
Wow, I feel like I'm coming in last place, however Sooper's location in the top right hand corner easily and simply states his actual location, however Old School see's this an reacts with great information......Hmmmmmm?
All together it sounds like people aren't paying actual attention the the issues and the information provided by the people asking for information????? There is plenty of information describing what needs to be done to fix it, just search as the information is there.
Old Jun 16, 2012 | 10:39 AM
tank99Dango
IMO, if the CAT is clogged, it's no longer functioning properly. not sure why the disagreement? I just asked a random question about the smell of rotten eggs because believe it or not, some people don't know about why they get that smell. Secondly, if it were my money, I would find the best deal, keep the CAT, if it wasn't supposed to be there, Dodge would not have wasted time in putting it on.
Old Jun 16, 2012 | 11:17 AM
shrpshtr325
THE ULTI-MOD
yes it is no longer functioning properly if its clogged (partially of course) we are discussing the diagnosis methods, if it is clogged it will likely still smell fine bc what does get through is being treated correctly, its just not letting enough flow through to run the engine correctly so the rotten egg smell would not be present
Old Jun 16, 2012 | 02:41 PM
tank99Dango
Are dodge pcm's not designed to give catalyst threshold codes?
Old Jun 16, 2012 | 10:01 PM
shrpshtr325
THE ULTI-MOD
the truck will most certainly throw a code for a bad CAT, that is why there is a post CAT Oxygen sensor in there, however it is unlikely that it will pick up a clogged CAT condition
