Two questions. Front sway bar and control arms.
Old Jun 15, 2012 | 04:44 PM
mackgraham's Avatar
mackgraham
Default Two questions. Front sway bar and control arms.
99 dodge durango 4X2 5.2 318. I need to replace my sway bar bushings. What size is the stock front sway bar? I will also be replacing upper and lower control arm bushings. When I reinstall my upper and lower control arms do the bolts need to be torqued?
Old Jun 15, 2012 | 05:29 PM
duran-go's Avatar
duran-go
My sway bar diameter for the same vehicle (99, 2wd, 318) was the 34.5 mm one. But I would get under there and measure it with a caliper just to make sure. There seems to be plenty of different sway bar diameters.
Upper control arm:
Pivot shaft nuts - 130 ft. lbs.
Pivot shaft to frame nuts - 155 ft. lbs.
Lower control arm:
Front nut - 130 ft. lbs.
Rear nut - 80 ft. lbs.
