Driver side window only works
Old Jun 22, 2012 | 03:46 PM
hobbyart17's Avatar
hobbyart17
Unhappy Driver side window only works
So I just bought a 2002 Slt and the driver side window panel is the only one that works to make the window go up and down and I have no clue why I have power to the switches at each individual window but wont go up or down please help
thanks for your advice in advance
Old Jun 22, 2012 | 04:36 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
the lockout switch in the drivers door is stuck in the LOCKED position, replace the drivers side master control panel to fix it.
Old Jun 22, 2012 | 04:56 PM
Sooper's Avatar
Sooper
I agree, though it might be possible to simply clean the switch. If not, replace it. It's an easy change.
Old Jun 22, 2012 | 06:25 PM
hobbyart17's Avatar
hobbyart17
is there a way to bypass the lock switch if not thats cool. I thought the same thing and I tried to take apart the master switch but it would come apart does anyone have any luck taking it apart from there durango.
thanks guys
Old Jun 22, 2012 | 06:54 PM
TravisN.'s Avatar
TravisN.
There is directions on which wires to jump in this thread.
https://dodgeforum.com/forum/showthr...r+power+window
Old Jun 22, 2012 | 10:42 PM
hobbyart17's Avatar
hobbyart17
Thanks TravisN that worked perfect and now thats one less thing that i have to buy from dodge the parts are so expensive but now if I could get the deforst button to stop blinking or flashing what it is doing because the A/C wont turn on and the Weather down here in North Carolina is gettin bad the last 2 days have been in the 90s and d*mn I need it to work
Old Jun 23, 2012 | 07:10 AM
shrpshtr325
THE ULTI-MOD
the defrost button blinking, is it only when you push the button to try and turn it on (btw the defrost button only runs the rear window and the heated mirrors)?
if its only when you try to use the defrosters there is likely an open heating element in the circuit.
Old Jun 23, 2012 | 10:58 AM
hobbyart17's Avatar
hobbyart17
no the defrost light blinks constantly as soon as you turn the key to the on position it starts to blink and nothing changes when you push the button it just blinks and I cant turn the A/C on i push the A/C button but nothing happens the light wont come one and the compressor doesnt start to run. I called dodge and they told me it would be 80 to diagnose it and then more if they have fix or replace anything.
Old Jun 23, 2012 | 03:45 PM
shrpshtr325
THE ULTI-MOD
it kind of sounds to me like something is wrong with the piece that those switches are in
