02 Durango Center Console Power
Old Jun 26, 2012 | 11:11 PM
mtnbiker717's Avatar
mtnbiker717
Default 02 Durango Center Console Power
I cannot figure out what is going on with the center power outlet inside the center console...I changed the fuse, pulled out the power socket and it's plugged in. I'm at a loss...Any ideas??
Old Jun 27, 2012 | 12:23 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
what is the problem with it? no power i assume?
the power outlet inside the center armrest is run through a fuse in the PDC under the hood, my guess is you changed the one in the drivers side door jamb which has 0 effect on that outlet or the one in the rear which are both fused in the PDC
Old Jun 27, 2012 | 01:24 AM
mtnbiker717
Yeah, no power to it. I did swap out the fuse under the hood and checked the fuses in the cab (visually) and all seemed fine, no discoloration. From what I understand by reading here, the rear and center are on the same fuse and the rear has power both with the old and new fuse. Is there a way to test the outlet to see if that is the problem, or just replace it and see? I'm just afraid there is a deeper problem with the wiring...
Old Jun 27, 2012 | 08:50 AM
shrpshtr325
THE ULTI-MOD
the center console outlet is in the circuit BEFORE the one in the back, if the one in the back works i would imagine that the issue has to be the plug itself, im nots ure how it is wired in, but if there is a plug take a voltmeter and see if you have power to the plug
i will also note that when talking about fuses visually inspecting them is NOT good enough,they can blow without showing any signs of being bad on a visual inspection.
Old Jun 30, 2012 | 11:51 PM
mtnbiker717
I fixed it, not sure what was wrong, I unplugged everything and plugged it back in a couple of times, and it is working again. I'm guessing that the contacts were not great. But thats what I did to fix it.
Old Jul 1, 2012 | 11:58 AM
Old_School's Avatar
Old_School
If it comes back i would unplug everything you did again and spray each one with contact cleaner and let it dry.
