1999 Dodge Durango 5.2L CAMs
Old Jun 29, 2012 | 12:17 AM
TFghost's Avatar
TFghost
Default 1999 Dodge Durango 5.2L CAMs
I have a 99 Rango with the 5.2L motor it is a 4x4 and looking to put a Cam in it, I have found 2 CAMs that say will fit and in different options All Made by Comp Cams
Computer Controlled
Vehicle: (1999) Dodge Durango
Engine: 5.2L V8 318CID GAS
Fuel Delivery: FI
Fuel Config: MFI
Engine VIN: Y
Engine Desig: RC
Specifics: Camshaft
Hyd. Roller
Lobe Angle 112 deg.
700-4800 Rpm; Adv. Dur. 254 Int/ 262 Exh; Valve Lift .480 Int/Exh
800-5000 Rpm; Adv. Dur. 262 Int/ 264 Exh; Valve Lift .480 Int / .512 Exh
900-5200 Rpm; Adv. Dur. 264 Int/ 274 Exh; Valve Lift .512 Int/Exh
Extreme Energy
Fuel Delivery: FI
Fuel Config: MFI
Engine VIN: Y
Engine Desig: RC
Specifics: Camshaft
Computer Controlled Hyd. Roller
1000-5000 Rpm; Adv. Dur. 264 Int. / 270 Exh. ; Valve Lift 480. Int/Exh ; Lobe Angle 114. Deg.
1200-5400 Rpm; Adv. Dur. 265 Int. / 273 Exh. ; Valve Lift 506. Int/Exh ; Lobe Angle 114 Deg.
700-4800 Rpm; Adv. Dur. 258. / 264 Exh ; Valve Lift 480. Int/Exh ; Lobe Angle 112 Deg.
If Anyone could Assist in this it would be greatly Appreciated
Thanks,
TF Ghost
Old Jul 1, 2012 | 04:37 PM
adukart's Avatar
adukart
I would do a search over in the ram section, those guys do alot more of these kind of mods then we do, mainly cause there are more guys over there.
