Coolant amount after flush
Old Jul 1, 2012 | 06:48 PM
hoyt66's Avatar
hoyt66
Default Coolant amount after flush
Ok...I flushed my system today with the hose. Let it drain. Replaced the t-stat. tightened everything back up used the "breather plug" on the 4.7 and filled the system up. It only took 7 quarts when then manual says the
system takes 14.1. I ran the engine up to operating temp turned on the front and rear heat. Turned off the car let it cool down and it's still full. What
did I do wrong? Thank you
P.s. the 7 quarts includes the overflow tank
Old Jul 1, 2012 | 10:01 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
you must have had water left in the block, im surprised its got 7qts left in it, but that is what i bet happened.
Old Jul 2, 2012 | 06:49 AM
hoyt66's Avatar
hoyt66
Got it. I read there are plugs in the engine block but that just doing a partial exchange without pulling the drain plugs would be good enough. Thoughts? Thank you
Old Jul 2, 2012 | 07:46 AM
shrpshtr325
THE ULTI-MOD
exchanging most of the coolant should be just fine, however you need to make sure that final fill is sill 50/50 anti-freeze to water, you can buy testers to check this
Old Jul 2, 2012 | 09:02 AM
hoyt66's Avatar
hoyt66
OK. I will pick one up tonight. Thank you again for your help
