CAMs Question
Old Jul 2, 2012 | 01:45 PM
TFghost's Avatar
TFghost
Default CAMs Question
I have a 99 Rango with the 5.2L motor it is a 4x4 and looking to put a Cam in it, I have found 2 CAMs that say will fit and in different options All Made by Comp Cams
Computer Controlled
Vehicle: (1999) Dodge Durango
Engine: 5.2L V8 318CID GAS
Fuel Delivery: FI
Fuel Config: MFI
Engine VIN: Y
Engine Desig: RC
Specifics: Camshaft
Hyd. Roller
Lobe Angle 112 deg.
700-4800 Rpm; Adv. Dur. 254 Int/ 262 Exh; Valve Lift .480 Int/Exh
800-5000 Rpm; Adv. Dur. 262 Int/ 264 Exh; Valve Lift .480 Int / .512 Exh
900-5200 Rpm; Adv. Dur. 264 Int/ 274 Exh; Valve Lift .512 Int/Exh
Extreme Energy
Fuel Delivery: FI
Fuel Config: MFI
Engine VIN: Y
Engine Desig: RC
Specifics: Camshaft
Computer Controlled Hyd. Roller
1000-5000 Rpm; Adv. Dur. 264 Int. / 270 Exh. ; Valve Lift 480. Int/Exh ; Lobe Angle 114. Deg.
1200-5400 Rpm; Adv. Dur. 265 Int. / 273 Exh. ; Valve Lift 506. Int/Exh ; Lobe Angle 114 Deg.
700-4800 Rpm; Adv. Dur. 258. / 264 Exh ; Valve Lift 480. Int/Exh ; Lobe Angle 112 Deg.
If Anyone could Assist in this it would be greatly Appreciated
Thanks,
TF Ghost
Old Jul 2, 2012 | 01:50 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
https://dodgeforum.com/forum/dodge-d...s-section.html
you put this question in the 1st generation forum within the last week, so why put it in here too? ill move it for you but you have already gotten some responses in your other thread.
