governor pressure solenoid replacement directions needed. please.
Old Oct 16, 2012 | 07:33 PM
Old_School's Avatar
Old_School
Originally Posted by mom_of4
Thanks! When I am done installing the OD/ Lockup Solenoid. It basically is the same as this job but I have to take off the valve body. After thats all said and done, About how many quarts do you think I will need? I just had my fluid drained and replaced with new tran fluid a week prior to working on my truck, thats why I wanted to reuse it. Its brand new fluid but if you still recommend not using it I get it.
with it only being a week old, as long as its clean (red in color), is ATF+4 and does not smell burnt or anything you should be ok. I usually recommend new fluid when someone asks about reusing because there are some that will reuse old,dirty fluid and wonder why there trans wont shift or work properly.
just for reference when i did mine last (Full drain dry) it took me 8 1/2 qts to show full.. Just draining the pan its close to 5.
