Tie rod ends/Steering gear
yes they go out the bottom BUT BEWARE WHERE YOU HIT IT!!!!! If you hit the edge of the arm where the ball joint fits in you will bend it and it will take you forever to get it rounded out to fit the new one back in.. Get a small solid piece of metal to place on the ball joint end and smack that B!t<h with a 5lb sledge and you should be all good. I just did mine not to long ago so I know the pain in the **** that it can be.
I've done mine quite a few times, it can be a little difficult with the arm on the truck. It will come out though, if you can't get it with a rachet use an impact wrench.
I took my arm off and used a shop press to push the joint out. It takes quite a lot of force.
Allright. You all convinced me that it was possible. I used a bottle of propane, busted my breaker bar, bent my wrench, and tore up my cheater bar, and finally got that ball joint out. Did anybody here need the special chrysler specific ball joint receiver cups?
The reason I ask is that the new ball joint I put in ended up getting messed up. I believe it might be due to the fact that the ball joint press I borrowed from auto zone maybe doesn't have the right size cup. The side got a little bit mashed and the rubber came off.
Anybody else have this problem?
