Support Braces?
Old Jul 30, 2012 | 10:31 AM
winkie74's Avatar
winkie74
Default Support Braces?
Has anybody ever tried putting a brace in the engine compartment to tighten up the steering a bit? I have a 1999 Durango 4x4. I had put a brace on my grandfathers 66 mustang and that made a world of difference even though it had come stock with a brace, but the new one was better designed.
Old Jul 30, 2012 | 12:40 PM
Sooper's Avatar
Sooper
Edited - Didn't understand question.
Old Jul 30, 2012 | 01:51 PM
that_guy's Avatar
that_guy
that's not what he means. Braces go across the engine compartment to stiffen the chasis and increase handling on sports cars. I've never heard of them for Durangos or any trucks for that matter. These are trucks and aren't meant for handling, so I doubt you'd find any unless they were custom fabricated.
Old Jul 30, 2012 | 04:34 PM
winkie74's Avatar
winkie74
Thats what i thought. Well has anybody had custom ones made?
Old Jul 30, 2012 | 05:13 PM
Sooper's Avatar
Sooper
What exactly are your goals? Are you driving the Durango past it's handling limitations and simply want to improve them or are you just looking for something to mod?
The stock frame is quite stiff...much stiffer than comparing it to either an old or new Mustang frame. All that brace does is keep the frame stiff and in place and the stock frame should be just fine.
If you're trying to improve handling, you'll have to go in other directions...I believe, than a brace connecting the shock towers. Lower it, lighten it, lower profile tires, adjustable suspension, and fresh rubber or poly bushings all the way around.
However, as mentioned, these trucks weren't designed for aggressive handling. They're trucks.
Old Jul 30, 2012 | 05:17 PM
winkie74's Avatar
winkie74
I had found some old braces off a 60's chevy my grandfather had and kept and i was going to throw them on with a little bit of modification. Basically im just trying to find something to do and i just set them up and it looks cool. I know it probably wont do anything at all.
Old Jul 30, 2012 | 07:48 PM
that_guy's Avatar
that_guy
really it probably won't do much at all id anything since our trucks are body on frame and not unibody.
Old Jul 30, 2012 | 11:24 PM
winkie74's Avatar
winkie74
Yeah. Itll just be a cosmetic thing.
Old Jul 30, 2012 | 11:25 PM
srch4me's Avatar
srch4me
Bracing won't do anything. If you wanna do something why not something that will do more than "look cool" trust me the frame needs nothing. If your steering is loose get the gear box rebuilt
Old Jul 31, 2012 | 12:11 AM
winkie74's Avatar
winkie74
the gear box is fine. it needs all new bushings and steering linkages in the front though. But that will happen when i have the time and money.
