99 durango won't stay charged
Old Aug 13, 2012 | 05:37 AM
Kimberley99durango's Avatar
Kimberley99durango
Default 99 durango won't stay charged
Replaced battery, had alt checked. Won't stay charged. I shut everything off when i shut it off. I have also checked to see if anything is draining the battery. Any ideas?
Old Aug 13, 2012 | 02:40 PM
pkucan's Avatar
pkucan
You will need a multi meter/VOM (preferably a digital one) to test the output of the alternator when running and for a parasitic draw when not running. The alt should be putting out at least 13.5 volts when running. With the vehicle off, doors closed and all lights off (pull the hood light bulb if you have one) the draw should be no more than 50 milli amps (.05 amps).
