My 2002 SXT with the 4.7...has squeeking noises as the suspension travels over bumps and dips in the road. Recently replaced upper and lower ball joins...tie-rod ends and front sway bar links...still have the noise...although its not as bad. A-arm Bushings? Front shock making noise? What do you guys think?
Thanks guys for the replies...as I stated above though...the ball joints and tie-rods were replaced....along with the front stabilizer links...but I guess i can try greasing the sway bar bushings..but it still seems like maybe it's a-arm bushings or maybe noisy shocks...sure I will get it eventually by process of elimination..
