Crankcase / PCV Valve
Old Aug 18, 2012 | 02:16 PM
wtemple's Avatar
wtemple
Default Crankcase / PCV Valve
I was I was doing the plenum gasket repair and when I was disassembling everything, the PCV valve broke in half. Not a huge problem. I didn't take the piece out of the grommet immediately. Well the good news is the plenum gasket repair went well. BUT..... upon reassembly, I was replacing the PCV valve and I don't remember if I removed the metal piece within the valve. Is it possible that it fell into the crankcase?
I don't want to have to take off the valve covers if I don't have to.
Old Aug 18, 2012 | 03:03 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
if you didnt take the piece out and put a new valve in its very possible that it fell into the valve cover, actually its very LIKELY
Old Aug 18, 2012 | 04:14 PM
wtemple's Avatar
wtemple
The bottom portion of the plastic PCV Valve was still in the grommet, and I was able to get it out. So it is possible that the metal piece fell in???
Old Aug 18, 2012 | 06:30 PM
wtemple's Avatar
wtemple
OK, after spending the past 3 hours researching and debating how to deal with this, I decided that the best thing to do is pull the valve covers and take a look.
The following post was both entertaining and helpful.
https://dodgeforum.com/forum/1st-gen...d-fell-in.html
