Shocks
Old Aug 20, 2012 | 09:18 AM
Old_School's Avatar
Old_School
Originally Posted by Rawyzf
Thanks, sounds pretty easy then. I should maybe get new bolts, as I'm guessing mine are pretty rusty too.
Soak the bolts the night before with PB Blaster (your can get it at any parts store, even walmart) then again about a half hour before your ready... they should then spin right off...
MONROE Part # 911220 - front
MONROE Part # 911140 - rear
you will need 2 of each...
Old Aug 20, 2012 | 09:22 AM
Rawyzf's Avatar
Rawyzf
Perfect, thank you. I have PB Blaster in the garage, so I am all good to go!
Old Aug 20, 2012 | 12:14 PM
Old_School's Avatar
Old_School
PB Blaster is a must for any garage even more so if there's a ride more than 5 years old in it!
Old Aug 20, 2012 | 12:32 PM
topdogcustoms's Avatar
topdogcustoms
I'm running pro comp es 3000 you can get them at 4wheelparts.com
Old Aug 20, 2012 | 12:52 PM
that_guy's Avatar
that_guy
I'd definitely make sure you have some extra bolts for the rear shocks (the fronts should come with new ones). Even with pb blaster and all that good stuff both of the top bolts on my rear shocks sheared apart. I replaced the 2 bottom bolts just to be sure too. Bolts are cheap so you may as well just go ahead and replace them
Old Aug 20, 2012 | 01:33 PM
Rawyzf's Avatar
Rawyzf
Long shot here, but do you have the part numbers on those bolts for the rear? If not, I'll run to the stealership and pick up a set.
Old Aug 20, 2012 | 02:50 PM
that_guy's Avatar
that_guy
no I actually just got them at lowes. they're a standard size, I just don't remember what size they were. I just got someone to give me a ride over there and match them up.
Old Aug 20, 2012 | 03:10 PM
Rawyzf's Avatar
Rawyzf
Thanks - That's easy enough, I have Home Depot about a mile away.
