No Park, Reverse or Neutral after replacing Shift Cable
Old Aug 23, 2012 | 06:20 PM
Rheath33's Avatar
Rheath33
Default No Park, Reverse or Neutral after replacing Shift Cable
Yesterday My gear shift cable broke on me (2001 Dodge Durango 5.9l) I tried to pull the lever to park and it remained on first, Had to towed home bought a new cable from the dealership installed it but it cannot shift into park or Reverse or Neutral, I check ath the trans linkage it only moves in three positions, anyone ran into this problem? Is there a solution other than taking it to a trans shop and paying a whop load of $$$$. Plz help
Old Aug 23, 2012 | 10:25 PM
master tech's Avatar
master tech
Site Moderator & Tech
If the linkage at the transmission will not go into park. Then you may have a broken rod that allow the transmission go into park. Yes i have seen this a few times.
