help no bus
Old Aug 28, 2012 | 10:19 PM
99durango5.24x4's Avatar
99durango5.24x4
Default help no bus
no bus!!!all power systems not working correctly
Posted from Dodgeforum.com App for Android
Old Aug 28, 2012 | 10:25 PM
99durango5.24x4
abs pluses,headlights pulse,gauges work then don't,ac don't work.fan is slow on high,if I push brake pedal radio go's off come on when released.power windows slow. i'm New!!!!!
Old Aug 28, 2012 | 10:26 PM
99durango5.24x4
headlights pulse will it's running!
Old Aug 29, 2012 | 09:43 PM
jim1999's Avatar
jim1999
usually mean the pcm is going out
Old Aug 29, 2012 | 09:50 PM
Russ50's Avatar
Russ50
Did you try to put another batt. in your D just to try an see if things works better ????
Old Aug 30, 2012 | 12:08 AM
99durango5.24x4
yes didn't change.
Old Aug 30, 2012 | 10:31 AM
Russ50's Avatar
Russ50
Have you done anything to test your PCM box,, Takein it to dealer??
Old Aug 30, 2012 | 11:37 AM
99durango5.24x4
how do I test it or is it dealer test only
Old Aug 30, 2012 | 11:38 AM
99durango5.24x4
tags dead can't drive it.
Old Aug 30, 2012 | 12:05 PM
99durango5.24x4
today I cleaned plungers under abs module. now it isn't bumping anymore but no bus is coming and going. if I turn on the head lights or ac/heater it pops up in seconds. but the gauges work off and on during and before turning any switches on like lights or ac while its running. ahhhhh.
