Engine Misfiring/stalling while idling/driving. MIL on
Old 09-01-2012, 09:44 PM
Sarodare's Avatar
Sarodare
Sarodare is offline
Default Engine Misfiring/stalling while idling/driving. MIL on
About a week ago my check engine light came on for the first time. I thought nothing of it until it started to flash one day and I noticed my durango running rough. I ran a diagnostic tool and 5 codes came up.
P1281, P0300, P0305,P0307, and P0308.
Since this has happened I've had my Fuel injectors cleaned, oil changed and cleaned my spark plugs.
Any idea what it could be with these readings?
Old 09-02-2012, 05:55 PM
shrpshtr325's Avatar
shrpshtr325
shrpshtr325 is offline
THE ULTI-MOD
the last 4 are misfire codes which is why the CEL was flashing, it does this whenever it detects a bad enough misfire, its a warning to shut the engine off before it causes any damage.
I would start by replacing the plugs (all 8 of them) with champion copper core plugs gapped to .040
as for the 1281 that is the engine taking too long to heat up, probably a thermostat stuck open, not knowing which engine you have this is all the details we can give.
Old 09-03-2012, 11:49 AM
sleeper15's Avatar
sleeper15
sleeper15 is offline
i had something like this on my 5.9L.
i replaced all the wires and plugs and still did it.
then i replaced the coil pack. thats when i noticed the outside shell on the coil pack was cracked, and most likly some moisture got into it.
so yeah, try replacing the coil pack.
Old 09-03-2012, 11:40 PM
Sarodare's Avatar
Sarodare
Sarodare is offline
I have a 5.2 98 Durango. I'm gonna replace the coil pack when I get paid Friday. Looking around online it explains alot of the problems I've been having.
Old 09-05-2012, 04:47 PM
Sarodare's Avatar
Sarodare
Sarodare is offline
Replaced the coil and problem still remains.. gonna check my cat and IAC I guess.. seems to be getting worse as I drive. I can feel it missing bad as I'm driving it doesnt' want to gain speed.
Old 09-05-2012, 05:50 PM
shrpshtr325
THE ULTI-MOD
open the hood and run the truck at night, my guess is that you see arcing wires.
i would REPLACE the spark plugs, wires, cap and rotor (champion copper core plugs, cap/rotor w/ brass contacts, good quality wires, 8mm is recommended)
Quick Reply: Engine Misfiring/stalling while idling/driving. MIL on
