Alternator external wiring help
Old Sep 2, 2012 | 07:48 PM
czjeeper's Avatar
czjeeper
Default Alternator external wiring help
I need a hand with finding a wiring diagram.
I grabbed a 136 amp alternator off of a '98 Durango 3.9 yesterday.
I also took the heavier wiring with the alternator.
I'm installing it on a 1992 5.2 engine.
The Durango wiring is also set up better for my engine swap (Jeep Wrangler).
My question is. There are the two wires that come off and go into the engine harness. One is dark green and one is dark green w/a black stripe.
I know what my wires go to, but does anybody know which wire goes were so I can splice them together?
Mine has a dark green that goes to SBEC cavity 20 and a dark blue that goes to the injectors/sensors.
Old Sep 2, 2012 | 09:00 PM
ryanaugust's Avatar
ryanaugust
Probably doesn't help but attached is the wiring diagram. The FSM shows dark green going into the PCM and Wt/DB going into both the PCM and the Transmission Relay. My D has the same colors as the FSM
Old Sep 2, 2012 | 09:46 PM
czjeeper's Avatar
czjeeper
Thanks!
The Durango doesn't match any diagrams I can find.
I went dark green to dark green and blue to dark green/black.
It should work fine, but my red top Optima took a crap during the install...freaked me out!
I jumped it and I'm getting 14V at the battery so I think I'm good.
Battery time...
