Front bump stops
Old Sep 4, 2012 | 01:46 PM
jmess's Avatar
jmess
Default Front bump stops
My front bump stops are toast. Just wondering if I'd do any damage by removing them and not replacing them. It seems like all the brake lines have enough slack to move that far. Just looking for a yes or no. Not to be called an idiot or made fun of. I'm also running the t/s lift and the body lift as well so chances are tires won't rub
Old Sep 4, 2012 | 04:14 PM
Sooper's Avatar
Sooper
Most lift kits come with new bump stops because as you've deduced, you'll never hit the stock ones with a lift.
The bump stops are important not just for protecting the wheel wells and body but the suspension components that will stress too much if flexed to far. Joints will start breaking.
I would recommend getting some bump stops that are appropriate for your lift kits.
Old Sep 4, 2012 | 10:06 PM
IndyDurango's Avatar
IndyDurango
Ask for a replacement "jounce" when buying new ones.
HTH,
IndyDurango
Old Sep 5, 2012 | 09:31 AM
adukart's Avatar
adukart
As sooper explained about the suspension flex. I would put some in, they should just pull out with a pry bar and push the new ones in.
Old Sep 5, 2012 | 03:28 PM
srch4me's Avatar
srch4me
Frankly all he has is a body lift and a ts lift. The body lift shouldn't affect the bump stops. And the ts lift isn't high enough to elicit aftermarket ones
Posted from Dodgeforum.com App for Android
