Blowing hot air
Old Aug 29, 2005 | 12:02 AM
daedalus26's Avatar
daedalus26
Default Blowing hot air
The blower on my 2001 SLT blows only hot air, irrespective of the heater setting. Any idea what's wrong?
Old Aug 29, 2005 | 03:58 AM
Dave in LB's Avatar
Dave in LB
Default RE: Blowing hot air
Heatercore is shot most likely or you need to have your AC unit serviced. My guess is the heatercore though.
Old Aug 29, 2005 | 12:50 PM
Digitoxin's Avatar
Digitoxin
Turn on your A/C , and open the hood and see if the A/C Compressor clutch
is engaging. If it is not , you most likely have low freon in your A/C system.
If its not , check for power at the comperssor connection, to be sure you have
power going to the compressor, and ground.
https://dodgeforum.com/albumphoto.as...Type=6&apage=7
