4.7 & Synthetic oil???
Old Sep 14, 2012 | 03:57 PM
JBIII's Avatar
JBIII
Smile 4.7 & Synthetic oil???
What grade of synthetic oil should I use in a 4.7 ltr Durango?? Ie. 5-20, 5-30, 10-20, 10-30 etc.
Old Sep 14, 2012 | 06:44 PM
Compactc9's Avatar
Compactc9
Same grade as you'd use with regular oil, they use 5w30.
Old Sep 14, 2012 | 08:38 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
yup same as regular, stick with the 5w30
Old Sep 14, 2012 | 09:14 PM
tooltime's Avatar
tooltime
What kind of filter can you use with synthetic, i use mopar or wix. How often should it be changed?
Old Sep 14, 2012 | 09:16 PM
shrpshtr325
THE ULTI-MOD
filter must be changed with every oil change, some say to change it in btwn at 5k mile intervals but as long as your oil change is under the factory recommended 7500 miles i wouldnt worry about changing it any more often than the oil
Old Sep 14, 2012 | 10:07 PM
tooltime's Avatar
tooltime
I have heard/seen on bottles for many miles something like 10,000 to 25,000. Just change the oil filter
Old Sep 14, 2012 | 10:11 PM
MoparMan1991's Avatar
MoparMan1991
The 1st Gen Durango had a recommended oil change interval of 7500 miles from the factory?
Old Sep 15, 2012 | 08:41 AM
shrpshtr325
THE ULTI-MOD
the 2nd half of the generation with the 4.7 did, im not sure about the 98-00s but 01-03 definitely i would personally never run it that long, but dodge says its ok
Old Sep 15, 2012 | 02:01 PM
JBIII's Avatar
JBIII
Smile
Where did you get your signature from???
I saw a cartoon in Field & Stream or Outdoor Life many years ago that said exactly the same thing. with a helicopter lifiting a Jeep out of a swamp. Never forgot it.
Thanks a lot for the info guys, I think I got the picture. 5-30 And I change the filter and oil every 5 to 6000 miles. I'll try Pennziol Syn.
Thanks again
