Check engine light with no codes
Old Sep 17, 2012 | 05:52 PM
thomas242's Avatar
thomas242
Default Check engine light with no codes
Well i had a few codes last week that i worked on and cleared. Now the check engine light as come on, but shows no codes on scanner? This is no cheap scanner, its the autozone one that cost around $100.
Any thoughts please feel free to share.
Edits: I unhooked batt and check engine is gone.
Old Oct 6, 2012 | 05:35 PM
one big mess's Avatar
one big mess
i was haveing tranny problems and took it to the garage to be fixed. Done. as i was driving home the check engine light came on. Back to the garage. as i pulled in the engine just shut off. they put the scanner on it and it said cannot communicate with the computer. we turned the key off then back on the check engine was off and no code was found. now everything on my dash will shut down. no tach, no speedometer, the oil pressure, the temp guage and the gas guage then the engine stalls and wont start. wait 10 mins then its back to normal. so I wish you luck. hope something posted here will both of us out
Posted from Dodgeforum.com App for Android
Old Oct 6, 2012 | 06:17 PM
Old_School's Avatar
Old_School
Sounds like a bad PCM to me...
Old Oct 7, 2012 | 08:26 AM
one big mess
Yeah that's what I was thinking. Is there any way of telling for sure if the PCM is bad before I go and buy another one
Old Oct 7, 2012 | 08:52 PM
thomas242's Avatar
thomas242
hmmm nvm, just noticed you guys was talking to some one else in my topic..
Old Oct 8, 2012 | 07:36 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
sorry to be the bearer of bad news, but $100 scanner is a pretty cheap model, and by removing the battery you performed the reset procedure on the PCM which clears all codes even the soft codes that not all readers can pick up
also idk why someone else hijacked your topic, im sorry that it happened.
Old Oct 8, 2012 | 09:28 AM
one big mess
Sorry didn't mean to highjack your post. I saw you were haveing code problems (codes not being read) I thought posting about my code problem also that we could both get help. Once again sorry. Good luck with your problem
Old Oct 14, 2012 | 10:01 PM
one big mess
Found out that on the 2000 and higher durango you dont need a scanner to godes the codes. drop me a line if this will help
Old Oct 15, 2012 | 08:54 PM
thomas242's Avatar
thomas242
Thanks for the reply's. $100($168 to be exact) is not cheap, but to each his own.
As for this durango i traded it off, so its some one else's headache.
P.S; I was not upset about the random post in this topic, so no apologize needed.
