Front hubd always engaged
Old Sep 18, 2012 | 09:48 AM
grant56's Avatar
grant56
Default Front hubd always engaged
I have a 2000 Durango and the front hubs sound like they are always engaged Any help?
Old Sep 18, 2012 | 12:55 PM
Duranged408's Avatar
Duranged408
The hubs are always active, the drivetrain is deactivated via the transfer case (switch on dash or manual on floor). If not in 4wd it's possible you have a bad bearing or joint in the shaft.
Old Sep 18, 2012 | 07:16 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
yup as stated the only disconnect in the front end is at the t-case, the entire front driveline is always spinning
