Need Ideas on Where to Mount 4" Tweeters
Old Sep 27, 2012 | 08:36 PM
mosplace78's Avatar
mosplace78
Default Need Ideas on Where to Mount 4" Tweeters
After 2 years of bashing my head, replacing every part known to man, I decided to keep my 2000 R/T. After $600 for a new heater core and $700 on new tires, I decided if I am going to keep it, it is going to sound good too! A whole bunch of research later I decided on an MTX system which consists of...2 2" tweeters and 2 6.5" mid bass driver in the front, 2 4" tweeters, 2 6.5 mid bass drivers in the rear, 2 12" Shallow Mount Piston Drivers in a down fire box, and everything is powered by a 5 Channel MTX amp... Cant forget the 48sq ft of Dynamat to stop the horrific rattle most cars have. I have spent the last week covering every outside skin with Dynamat...doors, wheel wells, hatch, pillars, ect. I do not recommend doing it unless you have a friend with long twig like arms...My arms are so bruised, I look like a strung out junkie with horrible aim.
Now I am at the point where it is time to begin the install and after opening the box for the 4" tweeters, I discovered they weigh almost 6lbs a piece and the mounting depth is close to 4". My question is, where in the rear doors should i mount these? I know I am going to have to cut into the panel, there is no way around it...but where? Any Ideas would be greatly appreciated!
Old Sep 28, 2012 | 02:14 AM
thomas242's Avatar
thomas242
I have seen people mount them in the panel above/behind the front seats. Not sure if that's an option, but if i can find a pic of the last one i seen I'll post it here.
Edit: like this
. btw mute the sound from video..
Old Sep 28, 2012 | 04:52 PM
lvphotos's Avatar
lvphotos
You normally mount them high. With that size your going to have to use the lower part of the door. Fish around for some room. I would angle them up at least. I put my leftover 1" tweets at the top of the a-piler. The rear are just like the front doors aimed at front seats.
Old Sep 30, 2012 | 09:49 PM
mosplace78's Avatar
mosplace78
Thanks for the ideas! I got everything mounted today, have a few more panels to put back in, have to mount the amp, tint we windows again, then waiting on the box which will be here on Friday, and I am done...for now. Check out the pics, I think it looks pretty clean.
Attached Thumbnails Need Ideas on Where to Mount 4" Tweeters-2012-09-30_17-39-31_256.jpg   Need Ideas on Where to Mount 4" Tweeters-2012-09-30_17-39-46_953.jpg
