98 Durango door mirro
Old Sep 28, 2012 | 02:06 PM
Russ50's Avatar
Russ50
Cool 98 Durango door mirro
Hey, Got the 98 D of mine an it has the factory mirror's on it,, My wife ordered a new set for me that are bigger an is 6X9 ,,, My mirror's are power but don't have the heat in them,, The one's my wife did order for me does have the heat,, Just wondering if they would still work as power an heated mirror's when I put them on,, It's rainning right now so I won't hook them up till later,, I just don't want to hook them up an mess them up some how where they won't take them back, They are for a 98,99, an 00 Durango what the paper says,,
Old Sep 28, 2012 | 02:44 PM
Old_School's Avatar
Old_School
Yes they should work... Your truck SHOULD be pre-wired for the heat even though it did not come with heated mirrors... they are wired to come on with the rear defrost.
If by chance yours is not wired for the heat, it should be tho, all you have to do is wire them up to a toggle switch or something.
Old Sep 28, 2012 | 03:10 PM
that_guy's Avatar
that_guy
yeah as long as you have the rear defroster (which surprisingly was an option) you should just have to plug them in be done with it.
Old Sep 28, 2012 | 03:52 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
as old school said, as long as the wiring is there already it will work, even if the heat wiring is NOT there, you wont hurt the mirrors in any way hooking them up and the power function will still work
Old Sep 28, 2012 | 10:07 PM
Russ50's Avatar
Russ50
Ok, Thanks guys,, I just wanted to make sure about it,, An yes I do have the rear defroster so I will try an get them on tomorro if its not raining,, Thanks again,,,,
