using key for codes
Old Sep 30, 2012 | 05:15 PM
tooltime's Avatar
tooltime
Default using key for codes
I know you can check codes by turning the key 3 times and if have a code it will show. Do you turn the key to acc? Will that only work if the engine light is on? thanks
Old Sep 30, 2012 | 07:29 PM
cummingetit's Avatar
cummingetit
You turn it from the off position to run (where the car operates) 3 times stopping on run the 3rd time. I believe it will show any stored codes even if the light is off.
Posted from Dodgeforum.com App for Android
Old Sep 30, 2012 | 08:57 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
it will show p-done if the light is off, it only shows codes that trip the light to read soft codes (codes that dont trip the lights) will not show up
Old Oct 1, 2012 | 01:23 AM
cummingetit
Sorry man didn't mean to steer you wrong. My mistake. The process of getting the codes if you do have a light is right though.
