changed injector, now no fuel
Old Oct 14, 2012 | 07:06 PM
ryder1964's Avatar
ryder1964
Default changed injector, now no fuel
I had a p307, changed coil, plug and injector. Now fuel pump isnt working. Swapped relays with no luck. Everything hooked up as before. 2001 with a 4.7.
Old Oct 14, 2012 | 11:47 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
I would check the fuse's with a 12 volt test light. If you have a blown fuse, the ASD relay will not have any power up the fuel pump.
