Durango Transmission
Old Oct 19, 2012 | 08:35 PM
TJ3NN3R's Avatar
TJ3NN3R
New Member
Default Durango Transmission
I have a 99 durango with the 5.2L and the 42RE tranny and the motor keeps killing the trannys. Im woundering if I bolt a 44RE up to it will it stop the problem.
Old Oct 20, 2012 | 05:47 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
unless someone swapped the 42 into the truck it has a 44 already since the 5.2 shipped with a 44re behind it.
so yes if you do in fact have a 42 swapping in a 44 will help, however if you have the stock 44 there is something else afoot bc you should not be going through that many of t hem, once they get rebuilt they are usually good for a VERY long time with only scheduled maintenance
Old Oct 20, 2012 | 06:19 PM
Old_School's Avatar
Old_School
+1 on that....
Personally if i had to pull my trans and rebuild one to put back in i would go with a 46RE as they are just about the same as the 44RE just a bit more heavy duty..
