1998 Dodge Durango Headlight Fuses & Relays
Old Oct 27, 2012 | 09:29 AM
WTCornwell's Avatar
WTCornwell
Cool 1998 Dodge Durango Headlight Fuses & Relays
I have a 1998 Dodge Durango 4x4 5.9L, I'm looking for the fuses and relays that provide power and function to the headlights. The current condition is the Headlights will not turn on. The tail and front marker lights all work along with the urn signals. On the dash I see a indicator that the hight beams are on, however they are not.
If posssible I need a wiring diagram of the headlights along with the location of the fuses and relays.
Thanks Again
Old Oct 27, 2012 | 10:38 AM
Old_School's Avatar
Old_School
Thanks Again
Below is the link to the 1998 Factory Service Manual. It will tell you more than you will probably ever wanna know about your truck. I personally have used it many times... Section 8W is all the wire diagrams and the connector pin-outs.
~~> http://www.mediafire.com/?xu9h0gt9bdcn6#95xauggyi3uc3
From the link ... Click Durango~>1st Generation~>Factory Service Manuals
Old Oct 27, 2012 | 11:01 AM
lvphotos's Avatar
lvphotos
The high beam is a indicator there is a fault in the circuit. Check fuse panel on driver side dash. Then if that's not it check under Hood the panels are well equipped with locations. Check bulbs. I had a wire from driver to passenger side bad. With hid bulbs the blue light stays on because low volts.
Old Jan 1, 2018 | 02:04 PM
Brenda Whitson Carroll's Avatar
Default I have the same issue
Thanks Again
Did you find any answers?
