Hard starting
Old Sep 4, 2005 | 02:17 AM
erroneous's Avatar
erroneous
Default Hard starting
Also this 1998 durango doesnt start until you crank it 3x or so, this is ongoing problem, even after a dealer tuneup. Dealer has attitude of "throw new parts in it until customer runs out of money" FTS
Old Sep 5, 2005 | 02:56 AM
hydrashocker's Avatar
hydrashocker
Default RE: Hard starting
Which motor do you have?[sm=confused06.gif]
Old Sep 5, 2005 | 01:41 PM
erroneous's Avatar
erroneous
Sorry for the lack of info...... 1998 Durango,
It's the 5.9 motor. This vehicle is driven by my wife and is totally stock. It has the towing package, and has <60k
Old Feb 15, 2008 | 11:41 AM
browncs63's Avatar
browncs63
This is not a question but a solution. Our company runs a 1999 Dodge Durango 5.9 V8, which was having problems starting. We have been online multiple times to see if others had a solution and we found that owners were spending 1000's $ trying to figure the problem out to no avail, replacing part after part.
The PROBLEM:
Drive the Durango shut it off - go to start and would crank only - leave it for a while - come back start right up. At times the check engine light would come on, stay on, and throw a P0340 code (according to manual and dealers - no Cam shaft sensor on this model - it was throwing a false code). Little by little problem got worse to point Durango would not start at all. Seemed like it might be factory alarm with engine kill.
OTHERS ONLINE TRIED:
Coil; Crank Sensor; IAC; battery replacement; new distributor cap, rotor and plugs; replacement and/or flash of PCM; Throttle Positioning Sensor; Fuses; amoung other items. Brought to Dodge they could not figure it out.
WE FOUND IT TO BE:
Distributor pickup which duals as a cam shaft sensor. This is located under the distributor cap. A $50.00 part solved the problem.
