crank sensor
Boy an I so tired of this durango and these little problems. Now I have determined that my no bus thing in the odometer is the crank sensor (thanh you Master Tech). Now will the crank sensor going/being bad cause the transmission to not shift properly. I hope because I have already replaced the 3-4 shift solenoid, the governor solenoid and the transducer thing. Please can someone help. I've owned this vehicle for 2 and a half months and was only able to put 150 miles on it
Posted from Dodgeforum.com App for Android
Did you set the bands when you changed the solenoids?
http://www.dodgeram.org/tech/transmi...T_band_adj.htm
Also, there is a shift cable that can be reset as well (second post):
https://dodgeforum.com/forum/1st-gen...uestion-2.html
Finally, if you are having problems keeping the truck in the correct gear I've read somewhere on here about tightening the nut on the transmission linkage cable that is under the vehicle. I can't find the thread with the pictures though.
