Transmission surges after shifting.. light throttle
Old Nov 10, 2012 | 10:41 AM
stompbox55's Avatar
stompbox55
Default Transmission surges after shifting.. light throttle
My 99 5.9 has started surging when shifting 1-2, 2-3 with a light throttle. If I give it more gas it goes away. Any idea what could cause this?
Old Nov 10, 2012 | 03:57 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
start by checking the trans fluid level (check w/ engine hot and running in nuetral on level ground)
if the fluid level is good, then the next check is the TV or kickdown cable being out of adjustment, the FAQ has a PDF for how to adjust it properly
and the last thing is a clogged filter, do a fluid and filter change using only atf+4 fluid, and adjust the bands, these are the most common causes of shifting issues.
Old Nov 10, 2012 | 10:11 PM
master tech's Avatar
master tech
Site Moderator & Tech
+1 fluid check and the throttle cable adjustment, I would add maybe a TPS sensor too.
Old Nov 11, 2012 | 11:35 PM
hydrashocker's Avatar
hydrashocker
Also a transmission output sensor could be the issue but I'm thinking the forward bands are out of adjustment. Also check the fluid level ensuring the truck is parked level and engine running in Neutral parking brake engaged and check the dip stick.
Old Nov 13, 2012 | 12:27 AM
stompbox55's Avatar
stompbox55
Thanks guys.. I was just getting ready to service the trans right before this happened.. will check tomorrow and let you know..
Old Nov 14, 2012 | 11:07 AM
stompbox55's Avatar
stompbox55
Took it to Cottman trans and the trans is fine.. the problem is engine related.. fuel injectors?
