what is this
Old Nov 10, 2012 | 04:08 PM
c4715's Avatar
c4715
Default what is this
Anyone know what that hose is/does? It has a small sucking/hissing sound when it starts to stall and die. Thanks.
Old Nov 10, 2012 | 07:48 PM
bwdakrt's Avatar
bwdakrt
Originally Posted by c4715
Attachment 17643
Return heater hose
Old Nov 10, 2012 | 10:15 PM
master tech's Avatar
master tech
Site Moderator & Tech
That hose would give you a coolant leak. If you are having a sucking sound, check for a vacuum leak. Manifold or brake booster.
Old Nov 11, 2012 | 09:36 PM
c4715's Avatar
c4715
Thanks guys. I had a coolant leak inside the manifold 6 months ago. My weep valve was clogged and the coolant leaked into the manifold and caused some damage. Mechanic fixed it up for me $800 but haven't had the leak anymore. New hose and other new things. Guess I will check it out. Thanks.
